Help from those who have done the Bob Bishop Conversion
To those that have done this conversion I need your help.
I have the conversion bracket kit but want to make sure I have the correct list of parts of the other materials I need.
Could you take a look at this list and let me know if I need to add anything to it?
12530682 Wheel Brake Cylinder/Caliper RIGHT FRONT CALIPER K
12530683 Wheel Brake Cylinder/Caliper LEFT FRONT CALIPER K
10445856 Brake Rotors / Drums RIGHT FRONT ROTOR
10445857 Brake Rotors / Drums LEFT FRONT ROTOR
12455799 Wheel Brake Cylinder/Caliper Hardware PAD ABUTMENT BRACKET
22163727 Hydraulic Brake Hose FRONT CALIPER BRAKE HOSE
12530697 Wheel Brake Cylinder/Caliper Hardware GUIDE PIN
12530703 Wheel Brake Cylinder/Caliper Hardware GUIDE PIN BOOT
22163795 Banjo Bolt BANJO BOLT
10139097 Brake Hose Hardware COPPER WASHERS FOR BANJO FITTING
Additionally I have three choices for brake pads.....opinions on which one to go with?:
12480154 Brake Pads and Shoes HAWK HP+ FRONT PAD SET
18039366 Brake Pads and Shoes DURASTOP FRONT PAD SET
88952008 Brake Pads and Shoes 2002 Z06 FRONT BRAKE PAD KIT
Thanks in advance for the help!
Re: Help from those who have done the Bob Bishop Conversion
Good deal...thx!
I'll be sure to order the correct quantity of those parts.
Probably GM Parts Direct would be the best place for those.
Henson071
12-30-2015 09:55 PM
tdigger9899
09-07-2015 10:56 AM
