how do i remove the rear springs from my 99 camaro?
iam trying to remove the rear springs from my 99 camaro and i jack the car up and placed a jack stand on my subframe and i supported the rear axle with my jack and i removed the shock bolt and i lowered the jack and the spring wont come out, theres not enough space to remove it, i need at least a few inches to get the spring out? how do i get the spring out do i remove anything else? what can i do to get clearance?
Re: how do i remove the rear springs from my 99 camaro?
You may have to unbolt the swaybar to frame mount and the lower control arm from the body. Try the swaybar frist. That may give you enough room.
07-04-2005 05:00 PM
Anderson
07-28-2002 10:57 AM
