How easy is to replace the rear control arm bushings?
Do you need a press to remove and replace the rear trailing arm bushings? If so, $30 for each side bushings and $30 to have them pressed out and in...I might as buy new arms....Any suggestions? Daily driver 6 speed....
Re: How easy is to replace the rear control arm bushings?
No you don't need a press.
Here's one of the better choices
http://www.summitracing.com/parts/LAK-20140/
While you're at it might as well change your instant center to get better performance with these:
http://www.hawksthirdgenparts.com/ca...nbrackets.aspx
slothgrant
08-22-2002 03:01 PM
