I get the center brake light (in the hatch) to work but that's it for brake lights
Old 01-05-2006 | 02:17 PM
34v6needhelp's Avatar
Ok, when I push on the brakes, I get the center break light (the one in the hatch) to work. But the lower brake lights don't light up (you know the ones above the bumper). I have been told it might be a switch...I don't understand that, so can anyone clarify that (if it's even accurate)
and any helpfull info would be great.
O and yes all the bulbs are new/tested working.
Old 01-06-2006 | 01:36 AM
Lower's Avatar
Re: I get the center brake light (in the hatch) to work but that's it for brake lights
Check your fuses.
Old 01-06-2006 | 07:39 AM
Yes, it could be the switch (on the brake pedal bracket). There are two sets of contacts in it. One for the 3rd brake light and one for the normal brake lights.
Old 01-06-2006 | 09:56 AM
a327vette's Avatar
Could also be a bad turn signal switch. Ive seen this many times.
Old 01-24-2006 | 02:31 PM
Joe Bellman's Avatar
This was the problem with mine a couple years ago. I took the switch off, cleaned it and the problem was solved.
10-31-2016 11:09 AM
squarehead
01-15-2015 07:02 PM
AlaskaZ28
01-01-2015 12:30 PM
Red97LT1
9
12-17-2014 06:13 PM
siguy
11-27-2014 10:07 AM
Quick Reply: I get the center brake light (in the hatch) to work but that's it for brake lights
