I need an EBCM
I need an EBCM
Anyone know where I can get an EBCM for a 94 Automatic?
ABS INOP light is on and dealer diagnosis is module.
They're looking for the part, (no longer mfg?) but I know they're gonna want serious $$$.
TIM
TIM
Is this is it?:
http://www.rockauto.com/catalog/rafr...1035874k320571
Otherwise, I'd check your salvage yard. A lot of times you can get parts like this for $40-$50 if you pull it yourself. Sometimes you can get them for $10-15 if the yard doesn't really know what the part is.
Re: I need an EBCM
Forgive me for being a noob but where is the ebcm? Is it to the left of the radiator under the intake tube and fuel lines. The thing with electronic connectors going into it as well as brake lines? It isn't mentioned in the book as to where it is.
Re: I need an EBCM
The electronic braking control module is in the passenger compartment, under the dash above the driver side kick panel.
The device you are describing is the ABS motor pack/modulator assembly.
I'm assuming you have a 93-97. You need to add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. That helps people provide more accurate answers.
bwellard
16
07-29-2019 07:03 PM
bwellard
14
06-30-2013 10:27 AM
