I need input on my brake problem please!!!
Would a brake rotor that doesn't slide on easily cause nasty scraping and knocking noises? My passenger side rear brake rotor doesn't seem to slide on nearly as easy as my driver's side one does. I have to hold each side and kind of shake each side back and forth whilst pushing it in towards the car. I know the rotor is not warped I just think the holes aren't lined up perfectly. Could I use a file or something to open up the holes a little bit? or is the bigger hole going to cause to much slack or make things worse?
I would get a wire wheel and put it on a drill and run it on the lip on the axle.
I'm guessing that the rotor is not going on easy because of some rust build up on the axle.
Give that a try I'm sure that will take care of it.
dluna333
15
03-13-2015 12:30 PM
07-04-2005 05:00 PM
