I want to do a complete suspension/brake overhaul and upgrade
I'm looking to make the car handle great, but my driving will be 99.5% street. I'm willing to spend some coin to make it work.
Help me out with your ideas and experiences. What you bought, where you bought it, how much you paid, etc. K-members, LCAs, shocks, springs, coilovers, big brakes, etc.
I talked to Sam Strano about my suspension and made a few purchases from him. Suspension: I'm running 35mm hollow front bar / 21mm 1LE rear bar, Koni SAs, 1LE LCAs, stock springs. Brakes: you can't go wrong with Baer Eradispeeds and Hawk HPS pads, that's my setup and I love it. Also installed stainless steel lines and a flush with ATE Super Blue fluid.
I also got and bought(again on the recommandation of Sam) his sway bar kit 35/22 with all the poly bushing.Man the car is a curve carver,totally magic
For the brake i got C5 brake kit(dual piston caliper pressure cast,full rib,12.8" rotor,directionnal vented,hawk hps pads) wich is exactly the same kit has the bear one but with cheaper$$$ replacement parts.You can get every replacement parts from your dealer or any parts stores wich is a big plus.The car brake really hard
For the lca i would go (since its a street car) wit some tubular one(no need for the box one wich are heavier for nothing) with one poly bushing ends for the chassis side and one with a rubber bushing ends for the rear end sides.Dont uses poly bushing on the rear end sides because they tend to bind a lot.
Since i didnt see it in your sig i would invest in some good subframe connector wich is gonna stiff up your chassis.
And i also choose to install a sphon adjustable torque arm.This will help you with traction and will also delete the rear transmission mount that apply a lot of stress from the stocker.
I think the best brake upgrade for your money is to get a set of TrackBrackets (the C5 Corvette conversion kit) and a full set of stock C6 Z06 brakes. Rotors, calipers, pads. Should cost you less than $1500, and you'll have 14" rotors with six-piston calipers.
That's what I hope to do. I need to confirm that TrackBrackets are indeed compatible with C6 Z06 calipers. I've heard that they are, but I don't know of anyone that's done this upgrade yet. I plan to, once I have money.
I say use the stock springs with Koni SA's. They will alloy you to lower the front about 3/4 inch and just remove the rear spacer to match height for the rear . Get either the strano bars or get a 1LE rear with a Hotchkis front bar. Get either the Addco torque arm from Sam Strano or the UMI adjustable. Get a rod end panhard rod. Talk to Sam about 1LE bushings for the rear lower arms or use poly ones. For the brakes either 98^ conversion with Hawk HP's for stock wheels or UMI makes a complete C5 conversion for I think 750(that is what I paid for mine) if you have 17's; stainless brake lines. You could do all this for around 2 grand and could go racing with it on the weekends if you want to. Handling would be greatly improved, but the ride would probably be better than stock.
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
