install questions
install questions
hey guys I am going to swap some parts from a 1999 camaro to 2000 camaro.
Front and rear sway bars-
Rear lower control arms-
****ADJUSTABLE**** panhard rod-
My question is are there any suprises that I should be ready for switching the stock and performance parts from car to car. D
Do I have to re-adjust the panhard bar?
Any tricks or special techniques you guys have would be greatly appriciated!
Thanks, Nick
Thanks, Nick
Re: install questions
Patience and a measuring device for the phb, or eyball it.
On the LCA's if they're poly bushed put some grease on the outer egde of the bushings and ithey'll slide up in the bracket easier. If they're rod ended it should go easily enough.
oh thanks ill be sure to do that.
also another question does it matter if i take off the sway bars with the tires under load, or if they are hanging in the air, because i heard somewhere that they should be under load for an easier install......... urban myth, or truth?
Chrisdude
07-24-2002 02:25 PM
