intermittent ABS light
have a 95 TA. occasionally while cruising (not braking), the ABS Inop light comes on and the low trac and brake lights flash. after a minute or so, they all go out. brakes are good. any ideas?
Re: intermittent ABS light
Those dash lights use a ground that's terminated on the passenger side inner fender, next to the red positive post. Common failure for this ground point to make poor contact and give you a "light show". Remove the ground stud and sand off the paint under the stud. Clean everything up and retighten.
jj_burchiel
03-21-2015 12:51 AM
dluna333
15
03-13-2015 12:30 PM
squarehead
01-15-2015 07:02 PM
