k-member
What type of driving do you do with your car? Mostly street? Mostly 1/4 mile? Street/strip? Daily driver??
If your car is more of a weekend cruiser / strip car, then that K-member is probably fine. If you're going to put daily use & abuse on the car, I'd suggest going with the stronger UMI K-member. It's still ~20 - 25 lbs lighter than stock, but it's definitely built stronger than any of the competition's. Check it out first before you make your decision.
FWIW, I have their Road Race version in my car (it's beefed up even more than their standard version) and it's clearly a solid, solid piece of equipment!!
i check it out!!!
I'm sure it's high quality stuff, but that has drag strip written ALL over it!!
The UMI K-member is certainly A LOT heavier built than that (UMI admits that their K-member "only" saves ~22 - 25 lbs off the weight of the stock K-member).
If you have any questions please ask and I am glad to help. If you are interested in purchasing a item please let me know and I will put you in contact with a camaroz28 sponsor that carries our product.
Thank you!
Ryan
i
Thanks for the interest and I think you will be very pleased with our item. It is designed to handle the abuse of both street and track.
Thank you!
Ryan
Thank you!
Ryan
Yes, I'm running factory A-arms with my UMI K-member. They fit no problem, and the longer adjustment slots allow for some pretty serious camber! (since I use my car on the race track, I've got about ~-2.5° of camber, and ~+4.5° of caster).
