Koni guys come in. need help
With the rear set of koni sa's came 4 rubber grommets, this being my first shock install i was wondering does 1 grommet go on the top inside the car and one under the car, or both inside the car? I know its a stupid question , but its a first time.
One sits on top of the shock, under the body. One sits on top of the body over the shaft. There should also be washers to put on the bottom of the bottom bushing, and on the top of the upper bushing. Nothing unique to Koni.... any shock you put in that mount will mount the same way.
mschmidt33
03-15-2015 07:20 PM
SMO Q
02-11-2015 07:13 AM
