Kore 3 default C5 front brake conversion
I want C5's up front and I'm tired of searching for a conversion used and don't have time to piece together. So I'm considering buying the Kore 3 conversion kit, as it's complete and the rotors are already painted ...decent price. Anyone have experience with it by using only the default calipers, rotors, and pads?:
KORE3 Industries LLC: On and Off-Road Performance Automotive Components
Even the default would surely be much better than stock.
Re: Kore 3 default C5 front brake conversion
I've been looking at and wondering about this same system. After a little research I found that swapping the Kore package's 2-pc rotors for Baer Eradispeeds (ebay), saves a little money.
A bump for ya... maybe someone has the kit and can comment further.
ive looked into brakes for a while now...
IMO, over all id spend 400 for a good LS setup....180 for conversion parts, 125 for slotted rotors, 80 for pads..
for c5, with the Kore 3 kit, slotted rotor, ceramic pad is 740 total.
IDK if the C5 is worth $350 more...
what do you guys think ??
Not sure about this Kore 3 company; I have an old set of Bishop brackets on mine with Powerslot rotors and they are above and beyond any LT1 setup. Definitely worth the time & cost.
Magenta_Hearts
03-29-2017 08:54 PM
carguyshu
01-22-2017 11:19 AM
Hurin
12-13-2014 07:38 PM
