LCA Install Question
I have a quick question about installing lower control arms: Can I remove/install LCAs with the rear of my car on ramps? Or does this load the LCAs so they can't be removed so I need to jack it up from the body??? Thanks in advance.
Re: LCA Install Question
You'll want to put the body up on stands and support the rearend with a floorjack. This way you can move the rearend up or down with the floorjack so you can get the LCAs in.
lbrowne
11-13-2011 04:25 PM
Chrisdude
07-24-2002 02:25 PM
