Is loud squeaky noise normal on Z28 rear end?
My rear end sure is squeaky! Is that normal for a Camaro? It's so loud that people turn their heads when I go over speed bumps. Here is a link to a wave file that was recorded while I pushed down on the rear of my Z28 a few times. I didn't push real hard.
Loud squeaky noise coming from rear end- 1998 Camaro Z28. (75K - Wave file)
Is that normal? Any suggestions?
Re: Is loud squeaky noise normal on Z28 rear end?
I had a similar problem when I bought my car from the original owner. Took it to the dealer because the car was under warranty and they traced it to panhard rod bushings. I suspect they sprayed some graphite lube on them and called it good. Try that and see if it helps your noise problem. Spray all bushings in the rear. Check the rear shocks as well.
I have the same problem when going over speedbumps. It might be your rear swaybar endlinks [I just had mine changed yesterday, but I have yet to drive it over a speedbump to see if it changed at all].
I've also heard that it might be the rear springs popping out of the spring perches
I will make a confirmation, it was my rear endlinks that made the squeaks. I just drove my car over a bunch of speed bumps today, noise is gone! $15 for a set of polyurethane rear endlinks at your local AutoZone.
oldschool
02-09-2016 09:21 PM
