Low Speed Vibration
Low Speed Vibration
Just put the c5 wheels on the z28 and I notice a slight vibration when I braking 20 down to 10mph for a stoplight. I can understand why I would get a vibration at high speed due to an imbalance but what could this be from?
I also get a pretty bad vibration above 70mph.
Sent from my VS910 4G using Tapatalk
Re: Low Speed Vibration
What year is your car (hard to believe someone could be here 8 years and still not have a signature with that useful info)? Did you check the hub holes in the rear wheels to make sure the wheels fit correctly over the rear axle hubs? That can be a problem when putting newer year wheels on 96 and older 4th Gens.
Sent from my SCH-I800 using Tapatalk
Darth Xed
13
07-22-2002 12:45 PM
