lower control arm advice needed
Old 11-30-2008, 07:30 PM
  #16
Shon Herron's Avatar
Originally Posted by hotheadbuddy
is there an adjustable set that would be quite and good for carving corners ? thanks.
the other option is the poly/rod end style.
Shon Herron is offline
Old 11-30-2008, 07:46 PM
  #17
hotheadbuddy's Avatar
im not sure but i hear they wear out and are noisey. i may go with the umi ones w/o crome moly, they still have to out preform stock.
hotheadbuddy is offline
Old 11-30-2008, 07:48 PM
  #18
The poly is stiffer than stock, so anything above stock is an improvement.
its a compromise, i would go with the poly poly units.
Old 12-22-2008, 08:25 PM
  #19
Question
ive decided to go with the umi 2081 crome moly i just needed replacement arms but i only want to buy ones that i would not need to replace . ive looked around and think these are the best deal for the money at this time with the discounts going on. what do you think ? or is there another set i should consider. im not looking for the best just the best for my purpose at a reasonable price. thanks for your help. merry chridtmas.
Old 12-22-2008, 08:48 PM
  #20
im sorry pt# 2018c but im not familiar with this brand.
Old 12-23-2008, 09:12 AM
  #21
UMI LCAs 2018 with CM option
Old 12-23-2008, 10:17 AM
  #22
Bud M's Avatar
Stiffer than stock is not the hot setup. It's not the LCA's job to be stiff when twisted. That's why rod ends are better for handling. They allow angle changes between the axle and the LCA. Its the job of the swaybar to control the axle angle, not the LCA. Take a look at the hotpart units if you want handling without the noise potential of rod ends.
Bud M is offline
thenewkid
11-27-2014 09:41 AM
BIGCOWL-IMP
11-21-2014 09:40 AM
PaulN64
08-08-2002 05:39 AM
PaulN64
08-07-2002 06:17 PM
DubbyZ28Camaro
08-04-2002 12:53 PM
Quick Reply: lower control arm advice needed
