Lower control arm bushings set...
What is everyone using and are the LCA's on the V-8's the same as V-6's? I am going to build a boxed set at work so I was going to get a set for free off of a V-6. So I will definatley need new bushings for all this. Also what is the deal with the relocation brackets? Will doing the LCA's and sub-frame connectors be a real traction improvement? Any info will be much appreciated. Thanks!
The LCA from a V-6 will work fine as long as you upgrade the bushings which i've done. As for the relocation bracket this will help if your having bad wheel hop of the line. As for the sub frame it will stiffen up the car. This is good for t-top or vert cars.
Vinny
Vinny
Originally posted by ArizonaZ
Energy Suspension and Prothane. I personally have been using the energy suspension, but heard good things about both.
[Problem] F-Bodyworld.com/Jon Massaro WARNING!!
DarkKnight
Buyer/Seller Feedback
05-11-2015 10:03 PM
