lower control arm questions....
I hear about how lca's help with traction and all so i was wondering what lca's are the best. Also do i need the relocation brackets? Basically, i dont know much about suspension (more of an engine guy) so any help would be much apreciated. thanx
Re: lower control arm questions....
Originally Posted by camaroz99b
mainly for drag but taking corners is fun too... what im looking for is good launch times for drag and i hear lca's can help with traction
You pretty much have to weigh the pros and cons of both.
Check these out, I just found them surfing around on the web and for the most part They are pretty simple to make but you get all of the High Performance ability of a Spherical Rod end LCAs but for a much lower cost. Im gonna give them a try this winter and see how it turns out.
Aluminum QA1 Spherical LCAs
http://www.crystalridge.net/cars/index.html
neat stuff,
-john
neat stuff,
-john
thanx for the info it will definitly help me a lot
Yep, i didnt notice till later that spherical joints on the end can be adjusted in and out, I thought that they screwed all the way in, but i was wrong, that makes both the LCAs and PHR Double Adjustable . Which for the price is awesom!!!
-john
[Problem] F-Bodyworld.com/Jon Massaro WARNING!!
DarkKnight
Buyer/Seller Feedback
05-11-2015 10:03 PM
