lower control arms
Re: lower control arms
some people say relocation brackets work wonders some people say they didnt notice.. same thing with subframe connectors tho.. Im getting them just because i think they will help. Meangreenz or something got them and said they were a huge improvement but that was with the lower control arms at the same time.
i think your in the wrong section tho..
Relocation brackets are not only for lowered cars. On a stock height car, bolting the LCA in the bottom hole will move the center of gravity closer to the back of the car making your tires plant harder.
You also want to decide what mounts you want on your LCAs. Poly mounts are fine for straight line vehicles but can cause the suspension to bind in corners if you like to carve canyons. Sperical joints on both ends are best for handling but can add a lot of noise to the car. I went with poly/sperical combo myself.
[Problem] F-Bodyworld.com/Jon Massaro WARNING!!
DarkKnight
Buyer/Seller Feedback
05-11-2015 10:03 PM
