lower trailing arms, panhard rod, SFConectors
Im looking to put these on my car aftermarket. I see that hotpart.com has all of these at a reasonable price. Have you guys heard anything bad about them or what do you suggest. Also shoud I go with the adj. panhard rod, my car is lowered and I would like to put 315s on the back in the near future. But it seems to me the solid one would be more rigid with less flex.
Re: lower trailing arms, panhard rod, SFConectors
I have never used any parts from the store you mention, so can't help you with that. But if you plan on running 315s in the future, you absolutely need an adjustable panhard rod so you can recenter the rear after you lower (or already are lowered) to prevent any rubbing. Strength won't be a concern unless you go with the ones that have the adjuster in the middle of the bar (very bad idea). Good luck.
adjustable panhard bar isn't really needed unless you are lowered.
i have 315 nittos on my 99, with BMR lca, brackets, sfc, and solid panhard...and have no rubbing problems.
i didin't even have to pound out the fender well.
Trevor98ramair
07-31-2002 02:43 PM
