Lowering question
Lowering question
I want to lower My car.I was going to go with Eibach Sportline springs and Blisten HD's.The car is a convertable and I was just told I can only lower it 1.3 in.(Will this be a noticeable differance?)and that it has struts up front.What do I do?
Re: Lowering question
If thats the case, and I'm sure You'r wright, what equipment do I get to lower MY car the max that I can?There is a large gap beteen the wheel and the top of the wheel well.Thanks.
The lowering springs will lower the car. 1.3" will be noticeable. More than that will cause you to have to be very careful of what you drive over or what driveways or speed bumps you can traverse.
Whats good shocks for a lowered car? My vert was dropped 1.5" and I've seen them as low as 2". At 1.5" I scraped on pretty much everything, had to be cautious of all speedbumps and had to dodge potholes like the plague. But damn, it looks good enough to make it all worth it.
I used to have intrax lowering springs which i am trying to sell, those gave me like a 2" drop but i hit and scraped on alot of things, so chose carefully, if u live in a flat area go for it, but if u gatta worry bout speed bumbs and sharp hills on turns and crap, forget it, i wouldn't go lower then 1.5. With those intrax springs i had like no gap between wheels and tires with 45/R17" size
I absolutely love the look of my Intrax 2" front / 1.8" rear drop. The tires tuck up flush with the wheel wells. However, the Y-pipe and cutout by the axle both scrape on everything. Even the smallest speed bumps cause scraping. Plus, any moderate bump in the road caused my rear to hit the bump stops.
If you want the look, Intrax can't be beat. If you want drivability and/or performance, look into something else. Personally, I'm pulling my Intrax springs out Friday night. Hotchkis 1" drop springs and KYB AGX adjustable shocks are going in.
I am using BMR springs and re-valved Bilstiens from www.Stanoparts.com.
The BMR springs lower the car a little over an inch, just perfect imo, and very noticable.
If you decide to go with revalved bilstiens, they are custom valved for compression and rebound, depending on what springs you are using so the shocks compliment your choice of springs.
Springs are up to you, but i strongly advise you to get custom valved shocks, the price aint much more than bilstien HD's, and you will get a much better ride quality.
oldschool
02-09-2016 09:21 PM
HectorM52
01-31-2015 07:29 PM
