Ls1 Brake Conversion
Re: Ls1 Brake Conversion
The front will work, but if he bought the Baer Kit, he is prolly still using his Spindles. you will need the LS1 Spindles.Check these out
LS1 Brake Prep
LS1 Brake Install
There is really no point to change anything on the rears cause you wont notice anything. LS1 Fronts on a LT1 car is the way to go
LS1 Brake Prep
LS1 Brake Install
![Thumbs up!](https://www.camaroz28.com/forums/images/smilies/thumb.gif)
Don't mess with the rears. It's a LOT more work than the front with minimal gains.
If you are just going to take his front calipers and rotors, you will still need LS1 spindles. If you can get his spindles, calipers and rotors than you are all set. I would recommend picking up a set of stainless flexible front and rear brake lines too.
Dan
Dan
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
