LS1 brake conversion
Okay just did this.. I have the LS1 lines ziptied to the LT1 body mount for the brake lines. Only did that because of how tight the lines were and were afraid of kinking them. Would the LS1 body mount for the brake lines solve this? Or using the LT1 lines with the LS1 caliper bolt? Do the earls or any braided lines have some extra length? Thanks for anyhelp.
Re: LS1 brake conversion
The LS1 lines and LT1 lines are nearly identical lengths. You can rebend the LT1 line mount bracket to make it work better. The LS1 bracket is different. I would bet it would solve the problem better and it shouldn't be expensive from the dealer either.
Re'
Re'
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
