LS1 brake upgrade
LS1 brake upgrade
ok i bought stuff for this and im just curious to if i have everything i need.
I have the spindel and everything connected to it all the way down to the rotors/calipers. its all still in one piece. Is there anything else i need like brakes lines or?
thanks just tryin to make sure i have everything before i start.
Oh and im buyin new pads and rotors. What a good paint to use on the calipers?
Re: LS1 brake upgrade
You need the spindle with hub, rotors, calipers, caliper mounting bracket, rotor, and brake lines. It sounds like you have everything but the LS1 lines. You can supposedly reuse the LT1 lines but i used the LS1 lines.
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
