LS1 brake upgrade use LT1 balljoints?
i am going to be replaceing my front control arm bushings and just thinking about ball joints too. But i am thinking i mine as well just put the LS1 brake upgrade on my car too if im going to be in that area anyway. because its a different spindle, do i buy upper and lower ball joints for a LT1 or LS1?
Re: LS1 brake upgrade use LT1 balljoints?
I dont know that there is 2 different ball joints for a 97 or 98. But so you know the spindles will work with either ball joint. I put my 98+ brakes and spindles on with some 1LE arms for my year model (94 Z28). Pretty sure they are one size fits all 93-02.
1LEs can be had for about $130 from Dal and come with new bushings and ball joint.
Replacement bushings and ball joint can run $75-100 for parts and require a shop to install the ball joint.
10-31-2016 11:09 AM
07-04-2005 05:00 PM
