LS1 brakes installed, bye bye LT1 crap
Old 08-21-2005, 07:53 PM
  #16
ZMAN Z28's Avatar
Re: LS1 brakes installed, bye bye LT1 crap
http://www.classictube.com/
ZMAN Z28 is offline
Old 08-22-2005, 03:26 AM
  #17
5.0THIS's Avatar
Originally Posted by kainZ
Does anyone know what parts are needed to upgrade the LT1 brake lines to work with the C5 brakes / Bishop brackets?
You dont upgrade the camaro lines. Like I just said above, you need new front lines. Stock C5 lines work nicely, and arent very expensive. All that needs to be done to the C5 lines is one of the alignment tangs on the hard line end needs to be filed off.
5.0THIS is offline
Old 08-22-2005, 10:06 AM
  #18
Patrick96Z28's Avatar
Originally Posted by SD LT1
I just got my LS1 swap done last night and I have a question for anyone who has done this also. How far out of alignment we your front tires after the swap? My left front was toed out quite a bit and the camber is way off on the right front. I'll be taking it to an alignment shop tomorrow. I got my parts from Rick at pick-a-part as well. The knuckles looked good before I put them on. Just wondering if I got a bent one or 2. Thanks for the help.
Hey Brian, no way are they twisted if you got them from Rick. The tie rods may be off a little with the LS1 spindles throwing the alignment slightly. Mine pulled barely to the left....alignment made it perfect.
Patrick96Z28 is offline
Old 08-22-2005, 11:58 AM
  #19
Z95m6's Avatar
I put LS1 spindles and took it back into the alignment shop and my alignment was still perfect. I think if your alignment is off that means your spindles are bent.
Z95m6 is offline
ddr698
01-09-2015 10:05 AM
Jazsun
12-29-2014 12:14 PM
07-04-2005 05:00 PM
vals95z
03-18-2003 03:45 PM
LS1346CID
08-27-2002 12:27 PM
Quick Reply: LS1 brakes installed, bye bye LT1 crap
