ls1 rear brakes on lt1
![Question](https://www.camaroz28.com/forums/images/icons/icon5.gif)
I was thinking about upgrading to zo6 red calipers all around. I've read to do this I have to upgrade to the ls1 rear brake setup. What I was wondering if I have to pull the axles to do this upgrade?
Re: ls1 rear brakes on lt1
I have read that LS1 axles are required for the conversion. I have also read the LT1 axles will work.
I wish someone can put this to rest once and for all.
I am wanting some rear LS1 brakes but I am waiting for a good deal.
Originally Posted by shoebox
Read this 3 times. ![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
You must swap to LS1 axles to use LS1 rear brakes.
Now that that is settled.
What is the difference between the 2 axles.
Wait, this post jUSt skrewed up my whole plan, I just bought a lt1 rear and then found a complete ls1 brake setup. now EVERYTHING ive read on thirdgen.org says it will jsut bold right up!? does anyone have pics of the problem area? is this something I can just modify? its just not making sense to me.
Well since thirdgen.org FINALLY got back up and running, I did a little more reseach and you CAN bolt LS1 brakes on an LT1 rear. theres a few ppl that have done it and one of them said he just spaced the caliper back a little. the rest said itw as a direct bolt up. hope that helps.
![](http://www.transamws6.com/pics/ls1_brakes/brakes2.jpg)
Wilson
07-21-2002 05:08 PM
