LS1 Rear Brakes on an LT1? Possible?
Re: LS1 Rear Brakes on an LT1? Possible?
http://re.smugmug.com/gallery/267980 go here REINER has done this swap and is a great guy to deal with
Originally Posted by 5.0THIS
The only thing you'd gain by doing it is a better parking brake design. Otherwise there's no point.
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
The rear brakes are practically the same size. If you change you must change the caliper mount and the axles in addition to the calipers and rotors. The cost to benefit ratio is not very high, IMO.
I have been told that the LS1 brakes are a an easy bolt on as long as you have all the brackets, cables, calipers etc.
There has also been som discussion that you have to replace the axles cause the LS1 axles are a tad longer or shorter or somthing like that.
Is this true?
Is this true?
Ok, thanks for the input. I have a extra set of calipers layin around somewhere I think I might try them and see if that will fix my problem.
Wilson
07-21-2002 05:08 PM
