LT-1>LS-1 front brake conversion brake line issue
I got one side on. I can't get either brake line to hook up to the steel brake line that goes into the C-clamp. How do I make this work? I also heard you can order Earl's brake lines? Does anyone know where I can purchase them? Or if there is a way to make the original brake lines work, that would be greatly appreciated.
ZMAN
ZMAN
Re: LT-1>LS-1 front brake conversion brake line issue
they will fit, they just need a little bit of manipulation
they will need bent (not kinked tho) carefully and the hangers that screw too the frame rail will/might need turned (take them off and rotate them)
thats what i had too do with mine
10-31-2016 11:09 AM
