lt1 camaro alignment kit
Does anyone make a kit like they do for the mustangs, my car is lowered and the alignment shop cant get the camber right. I know the mustangs have a caster/camber plate to fix this. Can I get one for my Z.
Re: lt1 camaro alignment kit
Same answer I posted on fbody.com.... "camber kits" are for cars with "strut" type front suspensions. Your 4th Gen is not a strut suspension, but uses unequal upper and lower A-arms. The lower A-arm mounting points have slotted holes for the bolts, allowing a fairly wide range of alignment.
Mine was dropped 1.8" and they had no trouble aligning it. Use different alignment specs for lowered cars.... I had good results with 0.1 toe-in, -1.0deg camber and +4.0deg caster. The 4th Gen FAQ has suggested specs for lowered cars as well.
oldschool
02-09-2016 09:21 PM
Hurin
12-13-2014 07:38 PM
12-04-2014 11:56 AM
12-01-2014 08:08 AM
