Lt1 vs LS1 alignment spec question
After I did my LS1 brake conversion and got it aligned, the caster is out of spec left and right (pos). Are the caster specifications different on an LS1 vs an LT1?
I thought the LT1 and LS1s had the same spec, except for the early 4th gen f-bods that had less caster(3.5 instead of 5). Mine set at +4caster both sides, -0.5camber both sides and 1/32toe-in. The spec calls for +5caster but the steering wheel is easier to turn with 4 and I can't feel any difference in direction stability.
What did your specs show?
Doug
Doug
oldschool
02-09-2016 09:21 PM
Brandon Wittmer
12-20-2014 09:51 PM
Hurin
12-13-2014 07:38 PM
ChrisFrez
11-23-2014 10:33 AM
