Madman Manual Steering Rack
Re: Madman Manual Steering Rack
The holes for the stock tie rod ends are tapered. My guess was he had to drill them out for the spherical rod end bolts to fit. I had to do the same thing on my race car when I installed the manual rack.
I used a 5/8" bit w/ a low-speed drill to ream out the tapered holes. I took my time, used a level and drilled them out on the car. Just make sure to take your time and lube it up well to prevent cracking.
