Moving Brake Lines; Need Suggestions
I recently installed a BMR K-Member which moved my motor over enough to allow the header to rest on the heat shield for the brake lines. As a result, the car vibrates from the header torquing against the heat shield which is attached to the frame.
I have come up with the idea of moving the brake lines in order to take the heat shield off. Do any of the steel braided line kits have enough slack to allow me to route the brake lines away from the header? Any suggestions?
squarehead
01-15-2015 07:02 PM
