my new brake pads wont fit!?
Old 06-03-2008, 09:48 PM
jeffcamaro2007's Avatar
the others are fine but the outisde passenger rear wont fit in. its looks like it isnt shaped right or is too big. i might be able to force it in but then it will be stuck and not work right.
jeffcamaro2007 is offline
Old 06-03-2008, 09:49 PM
Chevycobb's Avatar
did it look like the drivers side?
Chevycobb is offline
JJEXP's Avatar
Must mean the guy at the auto parts store sold you the wrong pads Or somebody yanked a pad, and put a different one in it's place
JJEXP is offline
Old 06-03-2008, 09:52 PM
ill look at that i think thats probably it
Old 06-03-2008, 09:53 PM
6SpdLT1Z's Avatar
1. buy correct pad
2. push piston in.
3. insert brake pad.
4. reinstall caliper.
6SpdLT1Z is offline
Chevycobb's Avatar
compare it to the pads you pulled off of it too
Old 06-03-2008, 09:54 PM
mdacton's Avatar
post in tech forums
mdacton is offline
Old 06-03-2008, 10:04 PM
Justin Horne's Avatar
Originally Posted by mdacton
post in tech forums
Werd. Don't be cluttering up the lounge with this useless drivel.
Justin Horne is offline
Old 06-03-2008, 10:16 PM
ok i snapped a ****ing bolt in half
Old 06-03-2008, 10:58 PM
so can i go to a parts store and get a replacement bolt? or is something i will have to special order?
Old 06-03-2008, 11:11 PM
idunno's Avatar
What bolt did you break, and where? Is half of it still stuck in the hole? Most likely they are available at the parts store. If it's just a standard bolt (not the sliding pins), then you should be able to find it at a hardware store.
And jesus, up until an hour ago I was on the east side of Aurora at the gf's place. I should have driven by and laughed at you.
idunno is offline
dave89gta's Avatar
Is it the caliper bolt? Be a little more specific...
dave89gta is offline
Old 06-03-2008, 11:13 PM
yes the caliper bolt. iwas able to get the rest of it all out and everything.
Old 06-03-2008, 11:16 PM
dave89gta's Avatar
http://www.autozone.com/R,APP709223/...ductDetail.htm
Old 06-03-2008, 11:29 PM
thank you
before i finish up....this is what i have been doing.
1 unbolt caliper
2 remove old pads
3 unbolt caliper mounting bracket
4 remove old rotor
5 put on new rotor
6 put caliper mounting bracket back on
7 grease outside of new pads/inside of caliper
8 put on new pads
9 compress caliper piston
10 put caliper back on
I also rinsed the new rotors with water. (i was told by someone else i had to wash them or something)
is this all right?
Quick Reply: my new brake pads wont fit!?
