my new brake pads wont fit!?
Old 06-04-2008, 02:08 PM
  #31
Mighty's Avatar
Originally Posted by Mighty
Take a picture of the pad that doesn't fit sitting next to its counterpart that does.
W3rd.
Mighty is offline
Old 06-04-2008, 03:56 PM
  #32
Chevycobb's Avatar
Chevycobb is offline
Old 06-04-2008, 04:03 PM
  #33
grossesexy's Avatar
Jeff how long are you going to be a moron and not just do what people tell you?
grossesexy is offline
Old 06-04-2008, 04:49 PM
  #34
shock6906's Avatar
Hey, I can jump on a bandwagon too! :-P
shock6906 is offline
Old 06-04-2008, 05:23 PM
  #35
shock6906's Avatar
I'll bet he couldn't find a file, so he's out there with some sandpaper trying to wear down his brake pad right now.
Old 06-04-2008, 05:48 PM
  #36
ssbowtie1's Avatar
The jeffcamaro2007 saga continues...
...whatever happened with the fuel pump?
ssbowtie1 is offline
Old 06-04-2008, 07:16 PM
  #37
shock6906's Avatar
It didn't fit, so he came here asking if he could trim it down with some tin snips since he didn't have time to exchange it back to the place he bought it from online.
Old 06-04-2008, 07:27 PM
  #38
V8 Slayer's Avatar
bahahahahahahahahah
V8 Slayer is offline
Old 06-04-2008, 07:29 PM
  #39
Mighty's Avatar
Mighty is offline
Old 06-04-2008, 07:31 PM
  #40
jeffcamaro2007's Avatar
**** you
I didnt take a pic because i didnt have time because i needed to go to work. I went and just bought a whole new set of pads and they fit fine. Ill just return the hawks.
with the fuel pump i "modified" it and made it work and its all good and back together now.
Now ive run into another problem when putting the caliper back on the caliper bolts wont screw in all the way to the slider pin because the slider pin keeps spinning.
If you really want those pics i can get em for you now if u want.
jeffcamaro2007 is offline
Old 06-04-2008, 07:35 PM
  #41
Chevycobb's Avatar
why the **** not...go get them
Old 06-04-2008, 07:54 PM
  #42
Old 06-04-2008, 07:55 PM
  #43
the top picture is the new pads i bought and second pic is new rotors
Old 06-04-2008, 07:59 PM
  #44
nitrojunky's Avatar
Usually the slider pin has a couple planes cut into it so you can hold it with an end wrench.
nitrojunky is offline
Old 06-04-2008, 08:06 PM
  #45
shock6906's Avatar
**** you
Haha, I didn't know you actually modified the fuel pump. That makes what I said even funnier!
Quick Reply: my new brake pads wont fit!?
