Need Advice on Steering Column Play
I have an 89 IROC Z28. The steering column is developing lateral play. Movement is on the tilting part of the column. Has anyone ever had a problem like this? Suggestions on a fix will Greatly Be Appreciated!
Thank You!
Dane R. Marley
Wynnewood, PA
610-896-0217 - home
610-299-6360 - cell with voice mail
Thank You!
Dane R. Marley
Wynnewood, PA
610-896-0217 - home
Re: Need Advice on Steering Column Play
You will need to partially disassemble the steering column (i.e. remove the steering wheel, etc.) and find the bolts inside there. Chances are they're loose.
14
08-11-2015 12:03 PM
whitehooptie
07-12-2015 06:10 PM
