Need help
Need help
I'm looking for a good drag suspension that will also lower the car a little bit. I was looking at the drag launch kit but i keep reading it actually lifts the rear a little more than stock. Thanks
Buy the QA1 shocks front and rear, with the Spohn coil-over setup for the rear. That allows you to adjust the front and rear height any way you want it. You could even lower it for the street and raise it for the track.
