Need Help with Complete suspension over haul drag setup
The best time i can run is upper 12's, and that is no getting the car to hook up well.
The Car: 94 firebird 355 lt1 built t56 trans 15 x 10 drag lites
Car will be mainly for the Strip but would like to have some normal street also
Upgrade: Front end: Struts and springs looking at the Q1 seems like everyone is going with those.
Mid Body: Subframe con., drive shaft loop, New drive shaft " for 12bolt or S60" and T A arm
Rear End: was planing on getting the Strange 12 bolt but now they have the s60 out and i was wonder what you guys thought about which one would be better. I know when i look it up before the dana were stronger but they weight a lot more. The price is about the same http://www.strangeengineering.net/ne...earendAD1.html
Also do you buy stock after market rear end parts to fit the 12 bolts or do you have to mod. everything " i am talking about the control arms and panhard rod" I am looking to get this done ASAP would like to get some feed back thanks lot guys
10-31-2016 11:09 AM
