Need help with shock/spring part numbers!!!
Here are the part numbers:
Delphi-made in USA 01100912 22199128 M48, it's a front, and have a yellow tag on the spring, all I can make out is that it says ABS, and the 2 second to the last numbers are 22
deCarbon- made in France FRONT 3300 0 BN, also front, has yellow tag on spring 22077190
rear spring- all I can make out is **077420
Thank you very much ahead of time.
James
The parts are supposedly off an 98+ SS Camaro, but I'm not sure seeing as the fronts have different part numbers
James
Brandon Wittmer
12-07-2014 12:15 PM
