Need help with shocks please
Can someone tell me if these are the Blistens I need? I searched and found slp Blistens, revalves, and HDs and Im getting confussed on what to get. I have an SS with the original Blistens still on it but the ride is gone and I think they are blown. I need a good daily driver.
http://store.summitracing.com/partde...5&autoview=sku
It's a little more complicated than that I'm afraid.
The OE shocks on your car are SLP Bilstein's. They were tweaked fronts vs. HD's, but the rears were the standard HD's at the time.
Since then the HD fronts have become much more like the SLP's (a bit of added rebound damping). But the rear HD's have also changed and for the worse. That's the number you brought up from Summit. And it remains to confirmed if SLP is still using the HD rear valving. But it would seem so since the old number they used is no more. That "new" HD rear valving is a mess... it's got too much compression damping and too little rebound damping. In fact it's much more like stock DeCarbon rears than the older Bilstein's every were.
To get around this issue, I simply use an older valving that is still made and works very well. In fact it's the rear shock I'd use when I used to Revalve fronts.
So I'd recommend HD's, but not the way you see them everywhere else. I do a kit that uses the rear shocks we've been using for a long time with the new HD fronts (which again are basically SLP fronts).
I'm also an SLP dealer, so I don't say this because I don't like SLP products in general. I simply believe it's the best, known, alternative and it doesn't add a cost premium to do it.
karpetcm
12-16-2015 09:07 PM
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
