Need help on suspension choices..
I am looking to purchase some worth wild suspension parts that will get my power to the ground. I was wondering if anyone has any real life experience with the non adjustable lca's and panhard rods. Do the poly bushings cause any more added noise to the car? Would one poly and one rod end be preferable? I currently have a 400rwhp car and I am now looking to get some worth wild suspension mods. I have all stock suspension parts and I am in need of an upgrade. I noticed today at 1,2 shift the wheel hop is insane. I am just running street tires. I am looking to purchase subframe connectors down the road. So any advice on what will help get the power to the ground with these two modifications and not cause any extra noise. Also, I am thinking of sticking with the stock sized tire and not lowering my car. Would the relocation brackets be worth the money, or have you had good experience without them?
Sorry for so many questions. Engine stuff I know a thing or two about, but when it comes to suspension parts I need some schooling.
I can borrow some ET Streets from a friend, so I want to make sure I can use them effectively.
Oh yah, this is drag car only, however I do drive it on the streets during the summer months. Would removing my front sway bar help with getting better traction? What exactly does removing the sway bar actually do, The only thing I could think of was lightening the front end up. What is its purpose?
Re: Need help on suspension choices..
You won't notice a lot of difference with the panhard rod..... it will keep the back end from "wagging" side to side, so its going to help you run the car a bit straighter at the track.
But, with BIG power, now you've got the front left coming up and the right rear squatting, bending the chassis and making the car difficult to launch straight. So now you need to eliminate that problem. That requires an airbag in the right rear spring, or a very heavy rear sway bar.
At this point, with no front sway bar, and a beefy rear bar, don't try and take corners fast.
Also consider adjustable shocks to allow you to loosen the front end at the track, "drag" springs, and and adjustable torque arm to control the pinion angle.
Thanks for all the tips! I was also looking on ls1.com and it seems maybe these dimples in my left rear quarter panel arent from someone hitting it. The guys on LS1 were talking about body flex causing dimples in this panel. I have about 7 of them about the size of a quarter in the left panel above the wheel well. Is this due to the fact that I have a uni body? Will the LCA's and the Panhard rod fix this? Or is this something that SFC's are going to be needed for?
So I am looking at Subframe connectors, LCA's, brackets, and Panhard rod? Do I need the subframe connectors before I get my LCA's and panhard rod? Or can I do the LCA's and panhard rod first? There wont be any fitment issues if I dont purchase SFC's first?
You can put them on in any order. I would get the LCA's and relocation brackets first because they would benifit you the most. Also depending on how much you race the car you might want to look into a new torque arm, relocated off the tranny mount.....but just as you mentioned above, some good drag radials will help you out more than anything.
