Need instructions on how to delete ABS components
I am ditching the ABS in my 96 6 speed Camaro and basically want to get some info on how to delete the abs parts from the engine bay to make things a bit more clean and shed some weight and be able to bleed the brakes a little easier. I'm very noob when it comes to brake parts so if someone could try to dumb down the procedure on how to do this I would be very grateful. Thanx
Re: Need instructions on how to delete ABS components
Get a delete kit from SJM. When you see what you have to install, it will be apparent what you have to delete:
SJM Manufacturing, Inc. (724) 478-5580
The ABS motor assembly and the EBCM are about all that will come out, plus minor lines.
CARiD
09-07-2015 08:21 AM
