Need replacement for Baer rotors
Some time ago I installed a Baer kit on my 94 TA. Nice big rotors and really great performance. Since I've been driving the car again regularly after a couple of years of disuse, I'm thinking of a brake job. The problem is, Baer wants 160 each for a set of relpacement rotors! That seems excessive to me. I may be able to thave them turned but I've got other issues with that.
Any advise on how I might go about finding a less expensive rotor that will fit my modified-from-stock configuration? If I remember correctly the rotors are just over 13" and no changes to the hub were required ( aside from slicing off the bracket for the OEM calipers, so all I need is the right size rotor with the same bolt pattern, right? Or am I missing something?
-Kevin
-Kevin
