Negative effects of overtightening front swaybar endlinks?
good question
don't mean to hijack your thread... similar Q:
How do you know how much to tighten sway bar end links anyway??? (I just "use the force", and make sure that both sides are similar.
thx
JT
thx
JT
Norm
Fortunately (?), it's mostly a fatigue thing, meaning that it takes a while, so it can't hurt to loosen and retorque what you've got. In general, the tighter you torque down the poly type, the shorter you can expect the endlink life to be if it's going to break at all. I will note that some combinations of endlink bolt and poly split bushings may trash the split bushings instead, but I have seen broken endlinks (they break through the threads just below the nut). One failure I've seen was on a 100% OE vehicle, so it's not just an aftermarket parts problem.
Without a torque wrench - and you need to be watching this closely - when the poly just barely starts to bulge add maybe 1/4 - 1/2 turn more. I'd use a little locktite blue as well.
BTW, a torque wrench is a good thing to have. If you only use one occasionally, a cheapie beam type with a pointer and a scale is enough (and is actually preferable to the click-type in terms of not having to calibrate it or having it lose the calibration for any reason).
Norm
Norm
carguyshu
01-22-2017 11:19 AM
96SilverRam
11-20-2016 11:19 AM
BLK1997Z28
05-01-2015 12:23 PM
