New front brakes...smoking?
I put new autozone $30 rotors on each front brake along w/ Gran Sport pads from Tirerack (seemed like a good price for some performance pads) I go them together and done, went to go beed them in. I did a few low speed brakes ( not until I was completely stopped) then a few high speed brakes as well and was very easy on the brakes the whole trip (15minutes) and went back home and let them cool. Today I took the car to the store and treated the brakes like normal, everything was fine until on the way back home I have to go down this big hill which has a light right at the end. So I had to brake fairly hard and for a good 10 seconds. I come to a stop and see my brakes and smoking and smelling. I go another couple blocks to a gas station and one of them seemed hotter then the other and smelled. The passengers side one seemed fine. But I saw smoke from both.
Is this normal for pad break in??? I did put some spray on the rotors which was conditioning for new pads to prevent squeeking.
The stuff I sprayed is like a silverish stuff that goes on the rotor. But I though all of that would have burned off already..odd. I'll see if it still does it after a couple days of driving to work.
same stuff I used was silver but came in a little thing you had to brush it on and let it soak for 30 min.
Just take it easy a few days....it should be fine, any chance you have or know someone that has a temp gun? the laser type?.....just point and shoot it at each rotor...see how much difference there is in temp.
Shouldn't be more than 50* or so
Don't know anyone with a temp gun....at the gas station I could noticebly put my face by the rotor on the drivers side and feel the heat, the passengers side wasnt as bad. Coulda been the wind too. Maby I'm over analyzing I guess I'll see how it does on the way to work tommrow. Thanks for the help..
Oh and the stuff I sprayed on was in an aerosole can. worked like spray paint.
You put some stuff on the rotor? ha ha ha. Never do that. The most you should put is that Anti-noise stuff you put on the back part of the Pad. And when you install new rotors make sure you clean the contact surface with some carb spray to remove any grease/oil that is added to prevent rust.
but I repeat myself, never put anything on the rotor or the face of the pads.
96SilverRam
11-20-2016 11:19 AM
12-04-2014 11:56 AM
