New Rotors, what pads?
I ordered a set of cross drilled and slotted rotors from WS6store and was wondering what pads I should go with for these rotors? http://www.ws6project.com/user_stor/...oducts_id=1598
I was thinking Hawk performance HPS pads http://www.ws6project.com/user_stor/...bd264cbc2a84f7
Any suggestions?
Any suggestions?
Re: New Rotors, what pads?
I don't know anything about those rotors but that's wicked cheap. I've Never heard of Dora.
I guess you could use those hawk Pads, I use those pads on my slotted rotors.
I'm waiting to see how much those front rotors weigh. For that price, they're probably a light casting.
For pads, I've been looking at Axxis/PBR. From what I've read the Axxis Matal masters have the same performance of the HPS, but with a better feel and they're less expensive.
Hawk HPS are perfect for the street. Just a little dusting, and quiet, and grab very well. If it's a track car, look to the Hawk HP+, but it's going to dust a LOT and works better once warmed up a little.
I have the Hawk HPS pads on my C5 conversion, and I love them.
Dan
Dan
Drilled don't serve any practical purpose. It used to be for off gassing of the pads, but that's not really an issue anymore. The slots can be a benefit to remove water from between the pad and rotor, but if the pads are designed correctly, slots are not really a benefit. Anytime you remove material from the blank rotor, you weaken it, and reduce the heat sink mass to pull heat from your calipers/brakefluid/pads. In summary, drilled rotors are all bling, and to a great extent so are slotted rotors.
Dan
Dan
what is the Wt. of a stock rotor? And how does WT. play a roll in how good they stop? how much Better would these Rotors be over stock? any one have any ideas? Just Slot'd all 4 coners. I need to do breaks this spring and that looks like a good deal!
I don't know why greed says that those rotors are too light. I just bought a set of stock front rotors from pepboys don't remember the brand but they are 16lbs a peice too. But I do agree with him that drilled and slotted are useless.
Weight plays a huge roll in how well rotors perform. I'll put it in simple terms. Rotors are a heat sink. The more mass that there is, the more energy (friction in this case) it will take to get them to a certain temp. Hit your brakes hard for a given amount of time on a light rotor and they'll heat up quicker and to a higher degree. Do the same on heavier rotors and they heat slower and to a lower degree. You get your rotor hot and the pads will be out of their temp range and thats when you get brake fade.
Lighter rotors also cool quicker, which allows for easier warpage. Ever wonder why they run cool down laps at races? Partially to let the brakes cool gradually.
16 lbs is LIGHT. IIRC stockers weight about that which is why they suck so bad. Brembo blanks weigh ~19 lbs and even the CHEAP Valuecraft $25 rotors at Autozone weigh ~19 lbs (19.45 lbs according to their website). Baer Decelerator x-drilled/slotted weight almost 21 lbs.
Still sound like they're a good buy?
