newb question, rear caliper removal
Re: newb question, rear caliper removal
The wheel, then it's just 2 bolts to remove the caliper from the rotor.
Removing the caliper completely; just pull/angle the end of the cable off the arm, compress the sleeve tabs in the bracket to remove the cable from the bracket; then pull the banjo-bolt from the line.
10-31-2016 11:09 AM
Hurin
12-13-2014 07:38 PM
