no rear brakes
Re: no rear brakes
No brakes in the rear will fail anywhere.......
Check the master cylinder for low fluid in the section for the rear brakes. Check the rear brake lines and the calipers (or wheel cylinders) for leaks. Blead the brakes.
You should have the "BRAKE" light lkit up on your dash, indicating that there is an imbalance in the front and rear portions of the braking system. Is it on?
CGM2010CAMARO
04-07-2015 07:44 PM
trefidy
07-26-2002 03:40 PM
