Ok I got the lowering springs on and today I installed ...
Ok I got the lowering springs on and today I installed the Rear Bilstein shocks. I noticed that after driving it around ..about 20 miles... the passengerside is lower that the driverside. passenger is 25 3/4 " (to the bottom of the rear fender..above the tire)and the driverside is 26 1/4". what is causing this? any info would really help out. Also what or how do I get rid of all the squeeking in that area? Thanks
Re: Ok I got the lowering springs on and today I installed ...
Originally Posted by Z06Z28
Which springs do you both have?
If you did, that might be the problem. It has a tapered grove / ramp that the spring sits in. If you rotate it the pig tail end of the spring will not sit down properly.
The wire on the spring is about 1/2". So if the spacer is turned you may have one side cocked up about one turn of spring wire.
I would suggest pulling the rear springs and marking the end of the ramp and the spring so you can make sure that both sides are sitting the same.
Z28
12-01-2014 08:08 AM
