Ok to reverse phb bolt?
I just want to make sure that it is ok if i reverse my phb bolt? The one on the passenger side, i was not able to slide it back in when i put in a tubular phb no matter what. Is it ok if the nut is towards the front? I dont think it would be a problem but I wanted to know if there was a specific reason not to.
Re: Ok to reverse phb bolt?
That bolt is bigger on the non-threaded part than the threads. It may not go in the other way without enlarging the hole in the bracket. Other than that its not important which way it goes.
Sergio
01-27-2016 04:27 PM
